- Hamdi-Amer changed review status to Awaiting Review
- 3 w
Real_Time_Motion paths a new technique to update motion paths in real time, It works with any kind of object like empties, cameras, meshes, and bones making your work on polishing the animation much faster, simpler, and easier.
UI improved
Couple of things before we accept:
Delete All Paths using Pause icon? Confusing. Delete icon is using I don't even know what icon, it just looks empty. Just use "X" icon there that comes with Blender. That's what users are used to. I suggest you follow UI conventions of Blender instead of inventing your own. "UPdate_Path", why even UP uppercase? It's all so confusing. 3. Empty "assets" folder should be removed from zip file 4. In code you use bl_icon when defining operators. bpy.types.operator has no property. Icons are defined when referencing them in UI.
Also, when switching "Update Mode" you need to deactivate and reactivate auto update to start working again, otherwise it shows that its active but its not. Can you fix that?
Done Thank you so much for your great support and amazing useful suggestions :)
Sign in to comment.
Ready for review
