- vuyghu2020 changed review status to Awaiting Review
- 3 mo
This is an addon that allows you to build your partybots maps in Blender. Partybots is a game on steam that lets you play create games. To create a map in partybots with this plugin you need to click on the tab partybots converter and then press add platform and a dialog box to fill in the peramiters is the defult expt size when you finish creating your map you can select all the parts you want to convert and click Compile marked to clipboard which will give you triggers to paste them into the game mode file located in C:\Users\USER\AppData\LocalLow\Party Bots\Party Bots\GameModes. When you paste the compiled into the file make sure it is after [triggers]
I fixed so the Clipboard permistion hase a reson why in this page and so the conveyer dose not add a extra space in the file
This extension requests the following permission:
To write the compiled output to the clipbord
Before approving this add-on, some small modifications will be required:
Less important modifications:
bl_info
can be removed as it is now stored in the manifest file.I added more info how to use the addon in the description
I added the tagline and discription to the prermisions
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Sign in to comment.
Ready for review
