- Hydrocallis changed review status to Awaiting Review
- 2 mo
This add-on allows you to insert keyframes for the rotation, scaling, and movement of specified objects at any location.
When you want to link an object (or another parameter) with a camera in an animation, it was a hassle to switch the camera from one object to another every time. I created this function to simplify that process. This add-on works for other cameras as well, but it is mainly designed for the camera you are currently using.
The keymap is also displayed in the add-on panel. The keymap of the selected object will appear in the timeline with Blender's functionality, but this makes the timeline more crowded. This add-on simplifies the keymap display, making it easier to check.
For example, to insert the angle of view of the camera that does not fit the magnification of the object changed by the parameters of the geometry node. This add-on allows for more convenient manipulation of the camera and object keys.
Additionally, you can conveniently operate the camera with the mouse when moving the camera by locking the view.
The influence values of the track constraint feature keyframes are now displayed in the panel.
By executing the real-time animation operator, changes in the influence property values can be observed as shown below.
For example, to insert the angle of view of the camera that does not fit in the magnification of the object changed by the parameters of the geometry node. The camera and object keys can be manipulated a little more conveniently via this add-on.
It is now possible to compare F-curves between the selected object and the target object!
It is now possible to compare and select constraints between the selected object and the target object!
Match check marks and jump functionality have been added to the keyframe list!
Thanks for your contribution to the platform!
Before approving the add-on, review the following points:
__pycache__
folder can be removed from the .zip.For the first part of your description, you can update it with:
This add-on allows you to insert keyframes for the rotation, scale, and location of a specified object.
You have multiple translation issues in your description. Ask me if you need help to make an English description.
@Victor-09
Sorry for the trouble. I deleted the pycache folder and unified the document in English.
Please review it.
Thank you.
uploaded new version: Add-on "Keyframe Tools" v1.0.4
updated previews
updated previews
updated previews
updated previews
uploaded new version: Add-on "Keyframe Tools" v1.0.5
updated previews
updated description
updated description
updated description
updated description
updated description
updated description
updated featured image, previews
uploaded new version: Add-on "Keyframe Tools" v1.0.6
updated previews
updated previews
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Sign in to comment.
Ready for review
