- Robert-Kezives changed review status to Awaiting Review
- 3 mo
After installation the addon will be located at: -> 3D Viewport -> N-Panel -> K-Tools
Any Idea, suggestion or critics please reach me out! You also can try my other addons!
Have you ever faced the problem of pressing F12 and a weird mesh popping up on your pretty render? And then you have to search through dozens of folders and subfolders to find that wild mesh to disable it for the render, only to fail? Well, this addon will certainly help you with this task.
Mismatched objects = Hidden on Viewport but not in Render or Vice-versa. (Also for collections if it is not marked as excluded in the Render Layer).
After the installation the addon will be located at: 3D Viewport -> N-Panel -> K-Tools -> Visibility Check
Check out my other addons! :)
No changelog for this release.
Very nice add-on!
Before approving this, here are some required modifications:
maintainer = "Developer name <kezives3D@gmail.com>"
K_Tools-Visibility_Check-ver_1_3.py
QoL Modifications:
bl_info
in the __init__
file can be removed as it is now stored in the manifest file.Hi Victor, thank you!
I have made the changes, hope everything is fine now!!
Sure! noted! it will be on the next release!
updated description
updated description
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Sign in to comment.
Ready for review
