This add-on provides export functionality for the ASCII Scene Export (.ase) format.
The format is largely defunct, but it is still in use in some older programs such as games based on Unreal Engine 1 and 2.
Scale
and Units
option from the export dialog. Users are now encouraged to scale their models correctly before exporting.This extension requests the following permission:
Export .ase files to disk
Export operator doesn't set default file name, it leaves that field empty. And if you don't manually put in name throws python error. Please set default name to avoid that, it will be very common error otherwise.
Thanks
Sign in to comment.
This is now ready for review.
