- DevilMayCry changed review status to Awaiting Review
- 1 mo
Menu
file
> Import
> Mixamo fbx(folder/*.fbx)
In the displayed import menu, each option has a reminder message when hovering over it.
Import Mixamo Fbx, and bake root motion keyframes.
No changelog for this release.
This extension requests the following permission:
Import FBX from disk
You need files permisson in blender_manifest
since it imports files.
You might want to add animation or rigging in tags to make animators aware of this
This add-on seems to use names in literal quotes without being escaped. Names may themselves contain quotes or other characters that need to be escaped.
For example:
data_path = 'objects["{:s}"]'.format(object.name)
is incorrect because object.name
may contain a "
character.
To resolve:
repr(...)
or the !r
conversion flag for f-strings or str.format
.bpy.utils.escape_identifier(..)
.Ref: curve.data_path
use.
Thank you both for reviewing !!!
repr()
to escape strings, because on lines 243 through 246 I set string parameters that are not going to be entered by the user, so there is no need to escape them; Because parameter
in f'pose.bones[“{parameter}”].location'
requires double quotes “”
, and escaping parameter
with repr()
or !r
would return single quotes “”
, which would lead to more code, and the The parameter set does not use single quotes in the case of ''
, so this is unnecessary.@campbell Thank you so much,this really solved my troubles. 2024-08-26 Updated:
v1.0.1 updated:
Sign in to comment.
Ready for review
