- Endertainer007 changed review status to Awaiting Review
- 1 mo
IK-FK Snapping Tool is a simple Blender add-on that lets you match poses between IK/FK controls. This add-on is a fork version of the IK-FK Snapping add-on by Mystfit that adds additional snapping options and improved UI.
With this tool, you can easily snap from IK to FK and FK to IK with just a press of a button. This add-on also allows you to save presets that enable you to switch from one snapping preset to another.
If you encounter a bug or problems, you can raise an issue on the Github repository or join my Discord server.
Added guide on how to use the add-on
Just updated the __init__.py
Error: Python: Traceback (most recent call last):
File "D:\Documents\Blender\Extensions\.experimental\ik_fk_snapping_tool\operators.py", line 25, in execute
bpy.ops.wm.path_open(filepath=preset_path)
File "C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py", line 109, in __call__
ret = _op_call(self.idname_py(), kw)
RuntimeError: Error: File 'C:\Users\admin\AppData\Roaming\Blender Foundation\Blender\4.2\scripts\presets\IK-FK_Snapping_Tool' not found
Open Preset Directory operator incorrectly assumes directory path, results in this error (at least on windows)
Just updated the OpenPresetDirectoryOperator
. Needed testing.
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Just updated the license to GPL 3.0. Needed testing.
I haven't done deep testing (I'm not good with armatures unfortunately), but everything seems good to me, and functionality is nice. If problems arise in the future I hope they can be health with bug tracker and reviews.
I would advise you to provide video for previews that shows your tools in action. Currently if you don't already know what you're getting there's not really a way to learn about it.
Thank you for approving my add-on. I do plan on making an overview video on how to use the add-on. But since I'm pretty busy, I might do it someday. Other than that, l'll be keeping an eye for for any issues or bugs.
Sign in to comment.
Ready for review
