- BlenderCN-LJ changed review status to Awaiting Review
- 2 w
Gesture Helper is a convenient tool that allows you to effortlessly control Blender using gestures.
It supports both slow selection and fast gesture operations, catering to diverse usage scenarios.
· Sub-level gestures are supported, enabling fine-grained control over your actions.
· Right-click and one-click addition functions simplify common operations.
· A revolutionary press-and-drag definition system allows you to create custom operation sets without interfering with existing shortcut keys, fostering a personalized workflow. · It comes with MAYA presets and quick Blender operation presets for a smooth learning curve.
· Supports both Chinese and English languages, automatically switching based on your system settings.
Especially for Maya users accustomed to using Hotbox, Gesture Helper helps you regain a familiar and intuitive workflow in Blender.
Feel free to raise any issues on GitHub, and let's work together to enhance Gesture Helper!
Version 2.0 release
This extension requests the following permission:
Import/export Gesture preset
Before we start diving into code review, can I ask how is this different from pie menus? I understand the visual part of it, it does indeed look very cool and arguably better/cleaner than pie menus, but I worry that this coolness comes on the expense of performance, because lot of GPU drawing needs to happen for this, and it is not trivial matter.
So, putting the cool design aside, talking about pure functionality, is this any different than pie menus? And before you answer I suggest you take a look at pie menu settings Preferences > Interface > Menus > Pie Menus and see how much it can be customized, as well as take a look at 3D Viewport Pie Menus add-on that utilizes some features that can be in pie menus that aren't in default Blender.
(I understand your confusion, perhaps I should save money to provide more English documents.) You can find the button to import gestures in the settings of the add-on (experience its purpose through default presets) Here is a video I recorded: https://www.bilibili.com/video/BV15M4m117ye/ Then, let me explain why I need to develop this add-on
I think the default shortcut key or pie meun is a standard. (Just like communicating in different languages, changing shortcut keys can create obstacles for ordinary users in communication and knowledge learning. (There are also annoying shortcut key conflicts)) But users still need to customize the functionality. Why destroy the existing shortcut keys? So I came up with another way - gestures, adding to the existing shortcut key system instead of replacing it. For example, pressing Z can pop up a shaping pie menu. You can also long press Z or press Z and drag the mouse directly, at which point you can directly pop up a gesture menu. 2) Quick operation, even one handed operation Long press to pop up the gesture menu, press and drag the mouse to directly execute the corresponding direction command. If set to the right mouse button, you can quickly switch functions with one hand 3) More levels than pie menu Pie menu has only one level, while gesture systems can support multiple levels. A single menu supports a maximum of 512 (8 * 8 * 8) commands. For example, you can use gestures to draw a "√" to save the file 4) Make customization easier - right-click directly to add commands to gesture menu Just like copying a drive, it can be directly added to the current gesture by right clicking on most commands. Finally, it has undergone considerable optimization in terms of performance. This tool was first developed in 2022 (demonstrated to Pablo during his last visit to Beijing, China), and although it was not publicly released until January 2024, it encountered performance issues in the early stages but made significant improvements after several refactoring attempts.
(Perhaps a deletion function should be added to the comments?)
For ease of understanding, I have added a new video that may let you know its purpose (along with my new song)
Sign in to comment.
Ready for review
