Fast switch between common languages via the buttons next to the top menu. 通过顶部菜单旁边的按钮, 快速的在常见的语言中切换
Change the button into an icon to reduce the space occupied
Generally seems fine, some notes:
blcn
are no longer meaningful, should be changed to this extensions name.OBJECT_MT_switch_language
is unrelated to objects. Perhaps FLS_MT_
prefix?Overall this seems fine though.
LGTM,
One suggestion I have: You can set two different languages by default instead of English both times, so that the add-on works as expected directly after installation and doesn't seem broken with the default settings.
Also, you can remove the bl_info
in the __init__.py
file as they are now stored in the manifest file.
Sign in to comment.
