- Natsune-Mochizuki changed review status to Awaiting Review
- 1 mo
Improve Drag-and-Drop for Importing Files, and Supports More Formats!
*.3mf
(Required Blender 3MF Format)*.abc
*.bvh
*.dae
*.fbx
*.glb
*.gltf
*.obj
*.ply
*.pmx
(Required MMD Tools)*.stl
*.svg
*.usd
*.usda
*.usdc
*.vrm
(Required VRM Add-on for Blender)*.x3d
*.wrl
Initial Release.
Changes from Previous:
permissionThis extension requests the following permission:
Import models from the disk
Thank you for your review! I added Files
Permission to manifest!
All good for me!
Some suggestions to improve your extension:
fbx
), you could only add the import with default
option. Removing the sub menu altogether.Open file via drag and drop
option could be renamed to import file
as the term "Open" can be confusing; it could lead the user to think it will open a new Blender file.Thank you for approving and provide feedback! I'll incorporate your improvements into the next update!
Hey everyone,
Just a heads-up about a recent change regarding the licensing of add-ons on the Blender extension platform. Moving forward, all add-ons will need to be released under the GNU/GPL 3.0 license (SPDX:GPL-3.0-or-later). This is mainly to keep things simple and consistent across the board.
Previously, we accepted various licenses as long as they were compatible with Blender’s distribution. However, to avoid any confusion and streamline the process, all add-ons using the bpy API should now be presented as GPL 3 (the same license the Blender bundle is distributed). Regardless of whether the original code was under GPL 2, or something else like MIT or ZLIB.
Existing add-ons versions won't be affected. However, new updates will need to comply to the revised requirements.
Thanks for understanding, and feel free to reach out if you have any questions.
Sign in to comment.
Ready for review
