The BoneEyedropper add-on allows users to easily select bones in an armature using a eyedropper tool. This tool is especially useful for selecting bones directly in the 3D view and setting up property for the constraint.
When bones overlap, Ctrl + mouse wheel Up/Down can now be used to search for bones in close proximity.
Fixed eyedropper behavior when operator is called directly. This fix now copies the name of the bone to the clipboard when called directly.
This extension requests the following permissions:
Import .blend from disk
Copy property paths to clipboard
I am super impressed that you managed to implement this through Python, and it looks really sick, and I hate to say this, but it's also inches away from being implemented in core Blender.
Although your version has some nice preview drawing, which I think is freaking cool, but I don't think that would be enough to justify having it as an extension.
Unless that PR never lands. Then having this add-on will be great! But hopefully it does land, soon. And isn't it the best outcome when an add-on's functionality makes it into core? :)
I agree that this feature should be implemented as a core feature, not an add-on. I have tested that PR. To select the bones of another armature using eyedropper from 3D View, the target armature must be in Pose/Edit mode. Is this a limitation in the implementation...? I wish I could do something for that PR since the purpose seems to be the same, but I know nothing about Blender C... sorry 😔
Yeah, that's currently a limitation, IIRC Christoph said he can't access the pose bones of an object mode armature because he's using the selection buffer for the eyedropper, and ofc if you try to select an armature in object mode, it just selects the object itself. So the pose bones aren't available in whatever function he's using.
But if your add-on can do that,maybe you could suggest to him how your implementation is doing it, and ask if it would make sense to change his implementation to that, to avoid this limitation!
Addon just converts the 3D coords of the pose bones of the constraint target armature to the 2D coords of the region and then searches for the closest one to the mouse cursor... so as he said, it cannot take into account the shape of the bones.
My implementation won't help him as it doesn't work the same as the standard eyedropper as one would expect.
Sign in to comment.
Ready for review
