Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Visibility handler
Visibility handler
Copy visibility from viewport to render settings or vice versa.
Add-on by DanielBystedt
About What's New Reviews Version History
Objects viewport and render settings Modifiers viewport and render settings Modifier properties viewport and render settings
Operator menu location in 3dView area : View > Visibility handler
Also reachable via the search menu (F3)
This addon copies visibility settings of objects, modifiers and modifier settings from viewport to render or vice versa.
This is useful when you are rendering and discovered that you forgot to turn off render visibility on some objects that were hidden in the viewport.
What's New
1.1.3 June 13th, 2024
Simplified init.py as per Dalais suggestion. Verified that the addon can be installed by drag and dropping the .zip in blender
Permissions
Developer
DanielBystedt
Rating
(5)
Version
1.1.3
Updated
1 y
Published
Feb. 25th, 2024
Downloads
6215
Size
8.5 KB
Blender 4.2  and newer
License
GNU General Public License v2.0 or later
Render
...or download and Install from Disk
  • 8.5 KB
Reviews
See all
  • JoacimSvedlund
  • v1.1.3
  • 9 mo
As mentioned, just with the addition of the "Enable/Disable in Viewport" button this would be great!
  • timdan
  • v1.1.3
  • 10 mo
This is so close to being great! The main issue is that this needs to look at the Disable in Viewport setting more than the "Hide in Viewport" as this is a temporary option, but the Disable in Viewport is a keyable option. Would also be great if this plugin copied all the keys from the Viewport Visibility to the Render Visibility, because as it stands, when visibility is animated, this plug-in loses most of it's usefulness.
  • Shuimeng
  • v1.1.3
  • 11 mo
After enabling the plugin, I don't know where to look for the plugin interface, and trying to click on hide doesn't synchronize the hide rendering, and the plugin use leaves me confused
  • DanielBystedt replied
  • 11 mo
You can always use the search menu (F3) to find operators and their menu location. The operator is located in the 3dView View > Visibility handler.
You need to run the operator in order to copy the visibility settings to render or vice versa. It is not a feature that is run at all times.
3.0
5 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
