Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on SRTM Terrain Importer
Import SRTM elevation data as accurate 3D terrain.
Add-on by NicolasPriniotakis
About Permissions Reviews Version History
How to use the addon : https://youtu.be/lFd7lqpWMZY
This addon imports SRTM (Shuttle Radar Topography Mission) HGT files and creates accurate 3D terrain meshes with proper real-world scaling and elevation-based materials.
What are SRTM HGT Files?
SRTM HGT files contain digital elevation data collected by NASA's Shuttle Radar Topography Mission. This mission mapped nearly the entire Earth (between 60°N and 56°S) using radar interferometry. The data is available in two resolutions:
  • SRTM1 (1 arc-second, approximately 30 meters resolution)
  • SRTM3 (3 arc-seconds, approximately 90 meters resolution)
Each .hgt file covers a 1° × 1° tile of terrain and is named according to its coordinates (e.g., "N37W122.hgt" covers the area at 37°N, 122°W).
Features
  • Accurate Scaling: Terrain dimensions are automatically calculated based on latitude
  • Real Elevation Data: Heights are preserved in real-world meters
  • Smart Materials: Automatic creation of elevation-based color gradient materials
  • Customizable Settings:
    • Adjustable vertical scale for height exaggeration
    • Controllable mesh subdivision levels
    • Choice of color schemes (natural terrain or grayscale)
  • Convenient Import: Supports both traditional file selection and drag-and-drop
How to Use
  1. Importing Terrain:
    • Method 1: Go to File > Import > SRTM HGT (.hgt)
    • Method 2: Simply drag and drop .hgt files into Blender window
  2. Import Options:
    • Subdivisions: Control mesh detail (10-200)
    • Vertical Scale: Adjust height exaggeration (0.1x - 5.0x)
    • Color Scheme: Choose between natural terrain colors or grayscale elevation map
Getting SRTM Data
Visit https://dwtkns.com/srtm30m/ to browse and select terrain tiles Create a free NASA Earthdata account at https://urs.earthdata.nasa.gov/ if you don't have one Download the desired .hgt files Files are named based on their coordinates (e.g., N37W123.hgt)
Use Cases
  • Landscape Visualization: Create accurate representations of real-world terrains for visualization
  • Scientific Terrain Analysis: Study geographical features and elevation patterns
  • Game Level Design: Use real-world terrain data as a base for game environments
  • Environmental Studies: Analyze topographical features and watersheds
  • Architecture Site Planning: Understand site topography for construction projects
  • VFX Background Creation: Generate realistic terrain backgrounds for visual effects
Technical Details
Mesh Creation
  • Generated meshes are properly scaled based on latitude
  • Each vertex position corresponds to real-world coordinates
  • Automatic subdivision based on user settings
  • Optimized for memory usage with large terrains
Material System
  • Uses Blender's node system for elevation-based coloring
  • Real-world height values drive the color gradient
  • Displacement for accurate height representation
  • Two color schemes available:
    • Natural terrain colors (default)
    • Grayscale elevation map
Metadata Storage
Each created terrain object stores:
  • Latitude and longitude
  • Minimum and maximum elevation
  • Tile width and height in meters
  • Original data resolution
Performance Considerations
  • Mesh density affects viewport performance
  • Start with lower subdivision values (around 50)
  • Increase detail as needed
  • Viewport clip range automatically adjusted for large terrains
Limitations
  • Limited to areas covered by SRTM (60°N to 56°S)
  • Some areas may have voids or artifacts in the source data
  • Very large terrains may require significant memory
  • Processing time increases with subdivision level
Version History
  • 1.0.0 (2025)
    • Initial release
    • Basic terrain import functionality
    • Real-world scaling
    • Elevation-based materials
    • Drag and drop support
What's New
No changelog for this release.
See all versions
Permissions
This extension requests the following permission:
  • Files
    Import SRTM HGT files from disk
Developer
NicolasPriniotakis
Rating
Leave a review
Version
1.0.5
Updated
4 mo
Published
Feb. 9th, 2025
Downloads
3579
Size
6.5 KB
Blender 4.2  and newer
Report Issues
github.com/Nikos-Prinios/Blender-SRTM-Terrain-Importer
License
GNU General Public License v3.0 or later
Import-Export
...or download and Install from Disk
  • 6.5 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
