Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    DEVELOPMENT
    • Roadmap
    LEARNING & RESOURCES
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Simple Deform Helper
Simple Deform visualization adjustment tool.
Add-on by ACGGIT_LJ
About What's New Reviews Version History
Blend Twist Taper Stretch One click animation Simple deform X lattice helper
SimpleDeformHelper
This is an add-on used to improve the Blender simple deform modifier.
You don't need to spend hours learning and memorizing a lot of skills anymore. Now you can use it to quickly transform and create transformation animations with just one click.
ANIME
· Support Mesh, lattice, and curve (0.2.4)
· Support Gizmo
· Support automatic upper and lower limit matching for all modes
· Support one click correction of bending deformation orientation
· Supports twisting in bending mode
· Support adding and deleting keyframes (0.2.4)
· Support Show Gizmo (Ctrl+`) switch controller(0.2.5)
20250308-202839
Usage
To display gizmos, you need select an object then add a simple deform modifier.
Red gizmo: Upper limit
Green gizmo: Lower limit
purple gizmo: Deform strength
When draging gizmos, you can pres X/Y/Z to lock on axis, hold Ctrl to keep relative distance
And, you can change origin control mode at tool settings to change limit behaviors, you can also scroll when dragging to change it quickly.
GIF 2024-8-28 15-24-17
limitations
Not able to support multiple SimpleDeform modifiers well, especially with overlapping deformation areas.
Currently only supports mesh or lattice objects
The next
[TODO]·Enhance the user experience of animation production.(in progress)
If you have any good ideas, please discuss them on GitHub
Support
If you encounter any problems or have any good ideas, you can leave a message on our Discord channel.
The end
谢谢大家
Thank you everyone
ありがとうございます、みなさん
감사합니다, 여러분
Danke, Leute
Merci, tout le monde
Gracias, a todos
شكرا لكم جزيلا
Obrigado a todos
What's New
0.2.7 March 20th, 2025
v0.2.7
Fix: angle gizmo control disconnect bug
See all versions
Permissions
Developer
ACGGIT_LJ
Rating
(167)
Version
0.2.7
Updated
1 y
Published
Sept. 4th, 2024
Downloads
95589
Size
169.5 KB
Blender 4.2 LTS and newer
Report Issues
github.com/AIGODLIKE/simple_deform_helper
License
GNU General Public License v3.0 or later
3D View Mesh Object
...or download and Install from Disk
  • 169.5 KB
Reviews
See all
  • gjKrypton
  • v0.2.7
  • 1 w
It is perfect, thank you.
  • Azad-Yesil
  • v0.2.7
  • 2 w
perfect addon
  • John-McCallahan
  • v0.2.7
  • 3 w
Recommended
5.0
167 reviews
5
4
3
2
1
Rate this Add-on Report an issue
  • About
  • Terms of Service
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
  • Code of Conduct
Organization
  • People
  • Jobs
Blender Network
Download
  • Latest Blender
  • Blender LTS
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Requirements
  • Benchmark
  • Flamenco
Extensions
  • Add-ons
  • Themes
Developers
  • Get Started
  • Roadmap
  • Docs
  • Forum
  • YouTube
  • Python API
  • Tools & Pipeline
Support
  • Community
  • FAQ
Get Involved
  • Education
News
  • Press Releases
  • User Stories
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
