Sakura's Rig Interfaces is a container Extension designed to make development of UI scripts even easier. The latest version expands on the original idea by adding in a dynamic UI loader, Skin Download Utility, and the architecture to more easily add features to the Extension down the
In time, I will be uploading tutorials to my Youtube on adding your own UI's to the addon.
Note: SACR is not included, and at this time must be downloaded separately
V3.1.0 is a small corrective release fixing some minor navigation issues I experienced with the UI in practical use as well as fixing some minor issues I personally noticed.
These issues and changes were brought about after a render that I worked on following the release of R7.4.0, in which I found the UI to be a bit cluttered and difficult to navigate, specifically around the face section. The changes made in this release are intended to make the UI more user friendly and easier to navigate. As well as adding in some missing Material options for the Irises and Sclera.
On the backend, a lot of dirty laundry was cleaned up, mainly regarding unused variables, useless characters, and bad naming semantics.
bl_options = {"REGISTER", "INTERNAL"} to all Skin Operatorsif __init__ = "main" statement as this module cannot be installed on it's own, and the statement's inclusion was redundant.This extension requests the following permissions:
Save and Store Player Skin Information and Downloaded Rigs
Download Minecraft Skin Information from minecraft.net
