Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Render from Terminal
Create script to launch render from terminal.
Add-on by nukkio
About What's New Permissions Reviews Version History
Render from terminal
Overview
A Blender Addon to write script file to launch renders from the terminal.
Write file .sh and, but poorly tested, .bat.
Launching renders from the command line is useful for:
  • automating the rendering phase
  • optimizing resources
  • adding external commands (editing renders, uploading them online, sending messages...)
  • launching the render remotely
With this addon the script creation is simplified and can then be modified and customized according to your needs.
With default values ​​this addon writes a script to start rendering the current frame with the project settings; clicking the "Write script" button creates a .sh and/or .bat file in the same folder as the .blend project, with the same name followed by "_render":[blend file name]_render.sh
This file is ready to be launched from the terminal with
./<nome blend file>_render.sh
The script
The created script has a function "startrender" which is called by passing several parameters:
  • the name to give to the render
    empty string to use the project settings
  • frames to render
    • 1,3: render frame 1 and 3
    • 1-3: render from frame 1 to frame 3, inclusive
    • 1..3: as 1-3
    • no value: the current frame when the "write script" button is pressed
  • Resolution Scale as "Resolution scale" nel pannello "Format"
  • render engine BLENDER_EEVEE_NEXT, BLENDER_WORKBENCH, CYCLES or empty string to use the project settings
  • render quality "max samples" for Cycles and "samples" for Eevee
  • scene to use
  • whether or not it should overwrite the renders
  • a python script to run before render
The values ​​for resolution percentage, render engine, render quality and overwrite are collected in a Python string that is passed to blender with the --python-expr parameter.
The other values ​​are passed with the corresponding blender command line parameters.
Use
Frame to render
In this panel you choose which frames to render
  • Render only current frame: renders only the current frame; (the same result is obtained if you leave the "frames to render" field empty).
  • Launch animation as in project launches the animation as set in the project; if the "Enable Override values" option is not selected in the script, Blender is launched with the -a option; if instead there are changes to the project settings ("Enable Override values" selected) Blender is launched passing the frame interval set with "Frame Start" and "End" of the animation.
  • frames to render
    • 1-3: render from frame 1 to frame 3 included
    • 1..3: as 1-3
    • the above values ​​can be entered together; e.g.; 1,3,5-10 (render frames 1 and 3, and frames 5 to 10)
  • animation as singles If there is an animation, e.g. 1-5, the command line does not have the animation -f 1..5, but the single separate frames: -f 1,2,3,4,5. Useful when used together with "new call each render"
  • new call each render For each frame indicated in the "frames to render" field a blender call is made. For example:
    • in the "frames to render" field there is: 1,3,5-8
    • if "new call each render" NOT selected:
      • Blender is launched only once by passing -f 1,3,5..8
    • if "new call each render" is selected:
      • Blender is launched three times, passing
        • the first time -f 1
        • the second time -f 3
        • and the third time -f 5..8
    • if "new call each render" is selected e also "animation as singles" is selected:
      • Blender is launched six times, passing
        • the third -f 5
        • the fourth -f 6
        • the fifth -f 7
        • the sixth -f 8
This can be useful if you need to reload the entire project before each render.
Additional commands
These are commands that you want to run before or after the renders.
Warning: these values ​​will be copied into the script without any syntax checking or anything else.
  • Start before launching the first Blender call
  • Pre before launching any Blender call
  • Python python file to pass to blender (-P pyfile.py)
  • Post after each Blender call
  • End after the last Blender call
Override values
With these values ​​the script will launch the renders by modifying the project settings.
  • Enable Override values Enable override
  • Output path Like the "Output path" field in the "Output" panel, if empty uses the project setting
  • Override overwrite + Overwrite With "Override overwrite" selected it allows you to choose whether to overwrite the renders or not
  • Render Engine Choosing which render engine to use:
    • Default (as set in the project)
    • BLENDER_EEVEE_NEXT
    • BLENDER_WORKBENCH
    • CYCLES
  • Samples rendering quality, "max samples" for Cycles and "samples" for Eevee
  • % As "Resolution Scale", 0: Use project setting
  • Scene Scene to load before launching the render (-S [scene name])
Write script
Write the script: [blend file name]_render.sh
Warning: The .bat file for Windows has not been adequately tested.
What's New
0.1.1 February 28th, 2025
operator name changed from "rft.writescript" to "render.writescript"
Permissions
This extension requests the following permission:
  • Files
    Create script to render from terminal
Developer
nukkio
Rating
Leave a review
Version
0.1.1
Updated
3 mo
Published
Feb. 27th, 2025
Downloads
1388
Size
8.7 KB
Blender 4.2  and newer
Website
extensions.blender.org/add-ons/render-from-terminal
Report Issues
github.com/nukkio/Blender-Render-From-Terminal/issues
License
GNU General Public License v3.0 or later
Pipeline Render
...or download and Install from Disk
  • 8.7 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
