This extension adds four simple geometry nodes-based tools under the "Normals" category in Blender. These tools let you work with Manip Verts, which are just loose/disconnected vertices, re-used to define custom face-corner normals for a mesh. Because they are vertices, you can precisely position them in edit mode like any other component.
After installing the add-on from extensions.blender.org, go to Preferences > Add-ons > Perfectly Normal
and use the controls to install the assets to a local directory, this will enable the tools in Blender.
Select a mesh and in the viewport menu choose Normals > Manip Verts: (Re)create
this will build the Manip Verts into the selected object.
In the modifiers tab Add Modifier > Normals > Manip Verts: Apply
this will add the visualizing modifier and you should see normals as lines in the viewport at this point.
Enter edit mode and move the Manip Verts around, you will see the surface normals change in real time.
Once you are done, go back to the modifier, check "Ready to Apply" and apply the modifier, this will bake the custom normals into the mesh and clean up all Manip Verts.
Object|Edit Mode
"Normals" > "Manip Verts: (Re)create" : Adds Manip Verts to a mesh, one for each face corner normal. Optionally, it can delete the original mesh and just return the isolated Manip Verts (used for a "multi-object workflow").
Object|Edit Mode
"Normals" > "Manip Verts: Remove" : Deletes all Manip Verts from a mesh.
Edit Mode
"Normals" > "Manip Verts: Tweak": A "Swiss Army Knife" tool. You can resize, converge, and clear modifications for selected Manip Verts. If nothing is selected, affects all Manip Verts. If any faces are selected, the corresponding Manip Verts for the face's corners will be affected. Optionally it will let you change your mesh selection to the affected Manip Verts or invert which are affected.
Modifier
"Add Modifier" > "Normals" >"Manip Verts: Apply": Using this modifier is required in order to see any results. Adds a "visualizer" modifier to show normals as lines and also applies modified normals to a mesh. It has support for a "multi-object workflow" where you can pull the Manip Verts and/or mesh surface from other objects instead of getting this geometry directly from the stack mesh. Apply the modifier to commit the custom normals.
This is ideal if you need to store custom normals separate from the mesh:
Duplicate a mesh object and (with the duplicate selected) choose "Normals" > "Manip Verts: (Re)create", but check the option to keep "Only Manip Verts" this will leave you with two objects, the original mesh object and another that only has Manip Verts inside it
Options for adding the modifier:
. Open the "Use External Geometry" panel and use the object picker for "Manip Verts" to select the duplicated mesh that only has Manip Verts.You should now be able to edit the Manip Verts object and see the custom normals being applied by the modifier, and can apply it when ready.
While editing, the number of Manip Verts has to be the same as the number of face corners or the visualizing modifier will not work correctly. In a later version I will likely change this to store the mapping in a custom attribute so the one-to-one mapping is not required, although right now I'm on the fence about adding "surprise" attributes to user's meshes for things like this as they cannot be namespaced.
No changelog for this release.
This extension requests the following permission:
Read/write asset resources from/to disk
