Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on NLA Midi Copier
NLA Midi Copier
NLA and Graph Editor tools for syncing animation to midi files.
Add-on by Cornerback24
About What's New Permissions Reviews Version History
NLA Midi Panel NLA Midi Panel with note filters Graph Editor Midi Panel Copying action to notes Quick copy tool Keyframe generation
Tools for syncing animation to a midi file. In the NLA editor actions can be copied to line up with notes in the midi file, and in the graph editor keyframes can be generated based on midi file data.
Steps to get started in the NLA editor:
  • Open the Midi Panel and select a midi file
  • Select an object
  • Select an Action
  • Click "Copy Action to Notes"
The NLA Midi section also has tools to further customize how the action is copied. Filters can be used for more control over which notes the actions are copied to.
The Quick Copy Tools section has tools for copying actions to multiple notes at once.
The Midi Settings panel has settings to override which C is displayed as middle C, the file tempo, and the displayed track names.
The Other Tools section has a tool to generate action strips that can act as non-linear transitions, as well as a tool to rename actions directly from the panel. The tools in this section are not midi specific.
The Midi Instruments Panel can be used multiple actions to be copied, and can be used to copy all the stored action in an Instrument at once.
Steps to get started in the graph editor:
  • Create an object with animation data. (Animation data is needed so that F-Curves can be selected. Inserting a keyframe creates animation data.)
  • Open the Midi panel and select a midi file
  • Select an F-Curve in the Graph Editor left-hand side panel
  • Select the lowest and highest pitches to be used in keyframe calculation. By default all pitches are used in calculating keyframe values. The calculation can also be based on only the notes in the selected midi track or only the notes in a scale.
  • In the Midi panel, Select a Unit Type. (For example if adding to a location F-Curve, select Distance/Length.)
  • Select the lowest and highest keyframe values to generate in Min and Max.
  • Click Generate Keyframes.
"Limit transition length" can be used to insert extra keyframes to limit the transition time between generated keyframes. Keyframes can be generated based on other properties besides pitch as well.
The Midi Settings panel is the same as in the NLA editor. The NLA editor and Graph editor midi settings are completely separate, so a midi file loaded in one does not automatically load in the other. If a midi file is loaded in the NLA editor, a button next to the "Chose midi file" button the graph editor will appear that can be used to copy the NLA editor midi settings to the graph editor, and vice versa.
The README on github has descriptions of what every button and selection does.
What's New
1.0.2 June 27th, 2025
Fixed a typo in the NLA Midi panel
See all versions
Permissions
This extension requests the following permission:
  • Files
    Read midi files from disk
Developer
Cornerback24
Rating
Leave a review
Version
1.0.2
Updated
6 d
Published
Sept. 16th, 2024
Downloads
126
Size
109.6 KB
Blender 4.2 LTS and newer
Website
github.com/Cornerback24/Blender-NLA-Midi-Copier/tree/blender-extension
Report Issues
github.com/Cornerback24/Blender-NLA-Midi-Copier/issues
License
GNU General Public License v3.0 or later
Animation
...or download and Install from Disk
  • 109.6 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
