The conventional method is too slow: Adding named attribute node, selecting attributes or entering text in the name socket, and sometimes change option. For me, named attribute node take up too much space, and I always hide option and socket that are not needed.
Used in Geometry Nodes and Shader Nodes. Try to list all available named attributes. Can also list Vertex Groups, UV Maps, Color Attributes, and Object Attributes. location: N-Panel-Node-Named Attribute List
Used in Geometry Nodes. Select the Stored Named Attribute node and press the shortcut key to quickly add the corresponding Named Attribute node.
If there is feedback, it might get done sooner.
常规方法太慢: 添加已命名属性节点,在名称接口里选择属性或输入文本,有时还要更改选项. 对我来说,命名属性节点占空太大,我总是隐藏选项,隐藏用不到的接口.
可以在几何节点和材质节点里使用. 尽量列出可用命名属性. 还可以列出 顶点组 UV贴图 颜色属性 物体属性. 位置: N面板-节点-命名属性列表
在几何节点里使用. 选中存储命名属性节点,按下快捷键快速添加相应命名属性节点
如果有反馈的话可能会早点做
-Introduces numerous optimizations, significantly improving upon many pre-existing shortcomings.
Great extension, making the use of nodes very comfortable
