Lattice Helper is an add-on used to create a matching lattice for your selected object/mesh with just one click in object/edit mode.(Developed by the ACGGit team in 2021)
Select one or more objects, right-click and select "lattice overlay“
Create a matching lattice for one object.
Treat multiple objects as a whole and create matching lattices for them.
Add lattices to each selected mesh object separately.
Select several vertices, right-click and select "lattice overlay“
Treat the selected area as a whole and create a lattice (even if it comes from different objects)
Create lattices separately by loose parts
Select lattice or object(s) in object mode, right-click and select "delete lattice“
Select lattice or object(s) in object mode, right-click and select "apply lattice“
·For ease of use, setting a parent between the object and the lattice is enabled by default
When there is only one object, the object is the parent
When there are multiple objects, the lattice is the parent
· High quality topological Mesh is beneficial for lattice control deformation
· Pairing with our developed Simple deform helper will significantly enhance the user experience
(2021.12.13)Blender3.0晶格助手V1.2正式版发布!
(2021.12.04)blender新工具!晶格助手BETA!更全能的一键实现晶格匹配绑定工具!
谢谢大家
Thank you everyone
ありがとうございます、みなさん
감사합니다, 여러분
Danke, Leute
Merci, tout le monde
Gracias, a todos
شكرا لكم جزيلا
Obrigado a todos
· Optimize code · Adjust the function name to "Lattice overlay ->Add lattice" · Remove the 3D View tag
Excellent. Thank you so much!!!
