Please note that Audio Analysis can take time, depending on your computer.
Lip Sync is a powerful Blender add-on that brings automated lip-sync animation to your characters.
In just a few clicks, analyze an audio clip and generate phoneme-based keyframes for your character's mouth movements. No manual keyframing needed — Lip Sync does the heavy lifting for you.
Lip Sync uses a robust pipeline of open-source speech and phoneme processing tools to ensure both accuracy and performance:
Vosk
Offline speech recognition engine that transcribes audio into text and phonemes.
Bundled for Windows, macOS, and Linux
eSpeak NG
Lightweight and fast phoneme synthesizer that converts text into timed phoneme sequences.
A custom build is bundled with the add-on for all platforms
Ensures correct mouth shapes in context-sensitive languages
On first use, the add-on downloads the required Vosk model for the selected language.
These models are then cached locally to your system, so:
You only download what you need, when you need it.
Try it today and let your characters speak!
This extension requests the following permissions:
Import Models / Extract libs to disk
Need to download Voices Models to enable lip sync
Really looking forward to the upcoming support for Pose Library phonemes! That's going to be a game changer for sure!! Great work and keep me updated please :)
Hey! Thank you, I really enjoy seeing my addon being used ^^ I just released a fix on frame range, and I just started working on the pose lib. It should be released soon enough ;)
Amazing! It works very well
