Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Import Pixel Art
Import Pixel Art
Imports pixel art as colored cubes or squares for each pixel.
Add-on by bloody_albatross
About What's New Permissions Reviews Version History
Import dialog, showing import options. Pixel art imported as cubes. Pixel art imported as planes.
This add-on imports pixel art images as colored cubes or squares. Pixels with 100% alpha are ignored.
NOTE: For best results the imported pixel art should actually have the apparent pixels be actual 1x1 pixels in the image. If not, there is an option to automatically down-scale such images, but it will not work for lossy images (JPEG) or if it was scaled to a non integer multiple of the original size and might be slow (see below for more details). Maybe you'd rather want to down-scale the image manually (using nearest neighbor option) in an image editor.
Features
This add-on imports pixel art images as colored 1x1x1 separate cubes or 1x1 planes in a single mesh. Pixels with 100% alpha are ignored. All pixels of the same color will share one material. The material can use nodes. The names of the created cubes and materials can be controlled through format strings.
Screenshot: Select image
If you use the option 'Separate Cubes' then the imported pixels are all parented to an empty object so they can be easily transformed as a whole. The cubes have a size of 1x1x1 so they can be easily moved around pixel-by-pixel while holding ctrl.
Screenshot: Imported as cubes
If you use the option '2D Mesh' all the pixels will be planes in one single mesh. If you still want cubes then simply extrude the whole mesh by 1 unit in the Z direction. Alternatively you simply can use the solidify modifier.
This option imports much faster and it seems it is also faster to work with a single large mesh in blender than to work with many small objects.
Screenshot: Imported as planes
Options
Import As
  • Separate Cubes: Separate cubes where each cube is its own object.
  • 2D Mesh: A single mesh that contains all pixels as squares.
Use material nodes
When this option is checked the materials of the pixels will use nodes.
Reuse existing materials with matching names
When this option is checked already existing materials that match the specified name will be used instead of creating new ones.
Auto down-scaling of up-scaled pixel art
Often pixel art is posted on the internet in an upscaled form, meaning one apparent pixel is actually e.g. 8x8 or more pixels in the image. When this option is checked the image is analyzed and automatically down-scaled. This might be pretty slow for big images, since this is all done in Python.
NOTE: This only works if the image was up-scaled to an exact integer multiple of the original and no other filters where applied. If the image was saved as a lossy format like JPEG this will fail pretty much always, since lossy formats kinda smudge the pixels. The used image should best be PNG, BMP, or GIF.
The algorithm is quite primitive, but works for many pixel art images.
Object Name
Pattern for the name of the empty object that will be the parent of all the pixels. This object is helpful when you want to transform the whole pixel art at once. You can safely delete it if you don't want it.
Pattern variables: {filename}, {use_nodes}
Pixel Names
Pattern for the names of the pixel objects.
Pattern variables: {filename}, {use_nodes}, {color}, {x}, {y}
Mesh Names
Pattern of the names of the meshes of the pixels.
Material Names
Pattern of the names of the materials of the pixels. Note that pixels of the same color will also share the same material. This way you can easily change the material properties of all pixels of the same color.
Patterns
In name patterns certain variables will be replaced with their respective values. Because these variables use a {name}-syntax if you want to include curly braces in your names you need to escape them as {{ and }}.
  • {filename} – The name of the file (not including the folder names).
  • {use_nodes} – The string nodes if the use material nodes option is selected, an empty string otherwise.
  • {color} – Hexa-decimal string of the color of the pixel (RRGGBBAA).
  • {x} – X-coordinate of the pixel.
  • {y} – Y-coordinate of the pixel.
What's New
1.2.1 September 14th, 2024
Added warning text in import dialog about too big image sizes.
Permissions
This extension requests the following permission:
  • Files
    Import pixel art from disk
Developer
bloody_albatross
Rating
Leave a review
Version
1.2.1
Updated
9 mo
Published
Sept. 9th, 2024
Downloads
8437
Size
5.7 KB
Blender 4.2  and newer
Website
github.com/panzi/blender-addon-import-pixelart
Report Issues
github.com/panzi/blender-addon-import-pixelart/issues
License
GNU General Public License v3.0 or later
Import-Export
...or download and Install from Disk
  • 5.7 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
