Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on Incremental Auto-Save
Improvements to Blender's Autosave.
Add-on by Mets
About What's New Permissions Reviews Version History
I made this add-on for two reasons:
  • Blender's autosave has let me down a number of times.
  • I want to share my UserPeferences across multiple computers.
Features:
  • Unlike Blender, this add-on never overwrites autosaves.
  • Unlike Blender, autosaves even if the path is invalid. It will fall back to your OS temp folder.
  • Unlike Blender, this add-on autosaves unsaved files (Unnamed.blend).
  • Specify more than one autosave path. First valid one will be used. Handy when you share your preferences across multiple computers.
  • Customizable number of stored backups and backup interval.
  • (Optional) Autosave on file switch. Even if you choose "Don't Save", a backup will be saved.
  • Preferences are saved to Blender's config folder, so you don't lose them when disabling the add-on.
What's New
1.1.0 August 24th, 2024
Add-on preferences are now saved and loaded to/from a file in your blender config folder, so they don't get lost when the add-on is disabled.
See all versions
Permissions
This extension requests the following permission:
  • Files
    Save preferences & .blends in chosen directories
Developer
Mets
Rating
(8)
Version
1.1.0
Updated
9 mo
Published
July 3rd, 2024
Downloads
12255
Size
71.4 KB
Blender 4.2  and newer
Website
projects.blender.org/Mets/CloudRig
Report Issues
projects.blender.org/Mets/incremental-autosave
License
GNU General Public License v3.0 or later
System
...or download and Install from Disk
  • 71.4 KB
Reviews
See all
  • SLCD_WTR
  • v1.1.0
  • 2 mo
Saved my big project when blender couldn't. I'd like to chime in with Brent-10 and Bimo-1, The option to create an autosave directory where the blend file already is would make this addon perfect.
  • Mets replied
  • 1 mo
Fair enough, since it's such a popular request I noted this down as a Todo. :) Thanks!
  • 满满小宝贝丫
  • v1.1.0
  • 4 mo
很棒的插件,终于摆脱了Blender数字后缀的自动备份了!能添加多个保存路径这个思路超级棒!!! 一个小建议:能不能通过自动检测场景有没有变化,比如在我编辑了场景后才自动保存?
现在问题是:只能根据设定的时间间隔自动保存而忽略了场景是否被编辑过,比如如果我出去吃饭或者睡一觉它就会吧前面保存的文件覆盖了,这样既浪费了磁盘寿命(例如项目文件很大的情况下)又会覆盖掉之前保存的副本(如果我睡着了,那么一觉醒来后所有自动保存的副本的内容将会一模一样) 前面说过,我个人而言很讨厌Blender的数字后缀的备份文件,我只想让它像C4D那样以时间命名备份文件,所以我会将Blender的偏好设置里的“保存&加载”下的“保存版本”设置为0个。
  • Mets replied
  • 4 mo
Heya. This is implemented to the extent it can be. If your file is unmodified, it won't autosave unnecessarily. However, if your file is modified, the autosave will not mark it as unmodified. So, if you fall asleep directly after saving your file while leaving Blender open, your backups won't get overwritten. Otherwise they will, and I can't change that.
  • Bimo-1
  • v1.1.0
  • 7 mo
Same as user Brent-10. I would like to have an autosave folder relative to my current file. Other than that. Top. Thanks for your work!
4.5
8 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
