Are you using Grease Pencil and find yourself switching a lot between modes and tools? Then GP Tool Wheel can speed up your workflow: it combines mode and tool selection in one delicious wheel.
F8
By default you can invoke the tool wheel with the shortcut F8
. You can change this shortcut easily by customizing your wheel.
The wheel appears when there is an active Grease Pencil object and the cursor is somewhere in the 3D viewport. Grease Pencil version 3 (in Blender 4.3 and higher) is supported.
Selecting a tool needs no explanation: click on an icon and you are good to go.
You can customize your wheel in the add-on preferences.
Go to Edit
> Preferences...
> Extensions
and look for GP Tool Wheel
. Click on the arrow on the left.
Here you can compose your ideal, tailor made wheel. Perhaps you want to change it in a kind of 'Quick favorites' menu, with only the modes and tools you often use. Or assign Tab
as shortcut, replacing the default pie menu.
In the preferences, you can define:
You can save and load your wheel preferences for distribution to other devices or Blender installs.
Blender 4.3 ships with the new Brush Asset Shelf, with default brushes and the option to define custom brushes yourself. For Grease Pencil, the Brush Shelf is active in Draw and Sculpt Mode. By default, GP Tool Wheel uses the Essential brush assets that ship with Blender.
But you can assign a custom brush to a tool in the wheel. Right-click on the brush and choose Set as Tool in GP Tool Wheel...
In the dialog that follows, select the tool in the GP Tool Wheel and click OK.
Now this brush will be activated when you click on it in the wheel.
At Github, you can find further explanation of how to customize your wheel.
gpencil_paint.brush.gpencil_tool
property was removedThis extension does not require special permissions.
It's not working in Blender 4.3.2
The best place for reporting issues is the Github issue tracker. In general, the newest versions of the add-on (v1.0.6 and above) are working in Blender 4.3.2. If you file an issue at Github tracker, I can ask you there about error messages in the console etc., to figure out what the specific problem is on your system.
Absolutely loved it, except it had a bug that forced me to disable it. Every time I would activate the tool it would change my pen's radius size. Fixing the radius costed me more time than the tool saved. I'll turn it back on as soon as it's fixed.
Thanks for reporting the draw brush radius issue. It should be fixed in today's update.
Really a great help ❤️ That makes the work workflow much easier! I totally recommend it for production. A must have👍
