Gesture Helper is a convenient tool that allows you to effortlessly control Blender using gestures.
It supports both slow selection and fast gesture operations, catering to diverse usage scenarios.
· Sub-level gestures are supported, enabling fine-grained control over your actions.
· Right-click and one-click addition functions simplify common operations.
· A revolutionary press-and-drag definition system allows you to create custom operation sets without interfering with existing shortcut keys, fostering a personalized workflow. · It comes with MAYA presets and quick Blender operation presets for a smooth learning curve.
· Supports both Chinese and English languages, automatically switching based on your system settings.
Especially for Maya users accustomed to using Hotbox, Gesture Helper helps you regain a familiar and intuitive workflow in Blender.
Feel free to raise any issues on GitHub, and let's work together to enhance Gesture Helper!
If you encounter any problems or have any good ideas, you can leave a message on our Discord channel.
Fix: new file bug
This extension requests the following permission:
Import/Export Gesture preset
Very useful and feature packed , its like a free pie menu editor , although documentation is very lacking
I just have one question , is it possible to trigger specific gesture based on selection mode ? so you can have the same shortcut trigger 2 gestures , one in say edge mode and one on face mode? I tried to make it work with the conditional expression but couldn't make it work, no pressure if you don't have the time to explain, thanks for the addon
hi, I just woke up. The gesture tool supports setting different gesture menus in different modes. You need to add an if/elif judgment condition. Sorry, my English is not very good. (Maybe you can come up to Discord and play with me?) https://discord.gg/uxajQRH
Love how intuitive it feels. Well done!
I did get an error when trying to move a custom op's direction from its default. Would you like to know more?
A great addition. Could you tell me if it is possible to implement (wm.call_menu)?
