Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on GeoNode Shape Keys
GeoNode Shape Keys
Sculpt on linked animated characters.
Add-on by Mets
About What's New Permissions Reviews Version History
Example of the add-on's workflow for sculpting on a linked asset.
GeoNode Shape Keys let you deform linked and overridden meshes using sculpt mode, for example to make small corrections to an animated character.
How to use
The add-on's UI is only visible on linked and overridden meshes.
It can be found under Properties->Object Data->Shape Keys->GeoNode Shape Keys:
You can then hit the Add button.
  • You are prompted for a UVMap, which should not have any overlapping areas within the object.
  • You can also give this shape a name. By default it will be named after the current frame number.
Once you press OK, you can start sculpting! You're not actually sculpting on your original mesh. A duplicate has been created for you, and the original was hidden. You can switch back to the original using this button:
Removing a GeoNode ShapeKey entry will also remove the relevant modifier and object. Don't remove those in any other way.
Why a UV Map?
If your mesh doesn't have any overlapping in its UVs, you can just use that. Otherwise however, you should create a separate UVMap for use with this add-on. The UVMap is used by the GeoNodes set-up to match the vertices of the real object with the local copy that you sculpt on.
Multi-object sculpting
The add-on also allows selecting multiple objects before pressing the + button. In this case, the sculpt object will have all your previously selected objects. The principle that the sculpt object shouldn't have any overlapping UVs still stands. An operator is provided to easily create UVMaps across all of your asset's objects without any overlaps, for use with this add-on. You can find this here:
What's New
1.0.0 July 24th, 2024
  • Initial Release, compatible with Blender 3.5 and above.
Permissions
This extension requests the following permission:
  • Files
    To load the necessary GeoNodes from its .blend file
Developer
Mets
Rating
(3)
Version
1.0.0
Updated
10 mo
Published
July 24th, 2024
Downloads
16281
Size
215.6 KB
Blender 4.2  and newer
Website
projects.blender.org/studio/blender-studio-pipeline/src/branch/main/scripts-blender/addons/geonode_shapekeys
Report Issues
License
GNU General Public License v2.0 or later
Rigging
...or download and Install from Disk
  • 215.6 KB
Reviews
See all
  • Smay
  • v1.0.0
  • 5 mo
Great stuff !!! I wished someday there was a built in tangent input for geometry
  • sfbdesert
  • v1.0.0
  • 10 mo
Very cool add-on! Hope it can be added to defualt blender some day.
  • q3tt
  • v1.0.0
  • 10 mo
Very useful add-on! Hope something like this can make it in to Blender by deafult!
5.0
3 reviews
5
4
3
2
1
Rate this Add-on
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
