This extension finds bad motion tracking tracks.
The way it works is that it highlights tracks that move differently from the others.
Basically, if all tracks move to the right, except one that moves to the left, then the single track moving to the left is likely wrong and should be evaluated by a human.
Compared to the Refine tracking solution add-on:
Minor bug fixes.
Tests were added for the badness scoring.
This is a fantastic add-on — thank you so much for creating it! It has made identifying problematic motion tracks so much easier.
I have one small feature request: It would be very helpful if we could select multiple trackers at once to quickly delete all the bad tracks in bulk.
Keep up the great work!
Gooooood
