This extension was part of Blender 4.1 bundled add-ons. It is now offered as it is, with limited support.
No changelog for this release.
This extension requests the following permission:
Requires access to 3D Coat and its directory
Thank you Bernt-Scholer !!
I managed to get it installed with the below changes (note the version from git differs - these are files are not all changed), however it now runs in Blender, but crashes with the error :-
File "C:\Users\memki\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\blender_org\coat_applink\tex.py", line 331, in createnodes group_tree.outputs.new("NodeSocketColor", "Color") ^^^^^^^^^^^^^^^^^^ AttributeError: 'ShaderNodeTree' object has no attribute 'outputs'
Hi. Version 4.9.37 only work for version 4.1 and earlier. For version 4.2 the working applink can be found on v2024.24 installation folder C:\Program Files\3DCoat-2024\data\ToolsPresets\InstallAppLinks\Blender4x. For version 4.2/4.3 follow this instructions: https://blenderartists.org/t/how-do-i-use-the-3d-coat-applink-for-blender-4-2/1540848/22. *note: GetBack command it is not working -we work on next addon update-. Meantime use node-wrangler addon to link textures.
