The extension adds a cad like measuring tool to your blender file. you can adjust the location of the texts, the size, the orientation. once installed you'll have four buttons: Cadify (changes the look of the viewport to mimic archicad) x, y and z buttons (which create the measuring tool aligned to the respective axis.
Improved the dimension tool and added new ones, Also rudimentary conversion to imperial units.
could you elaborate on that, I'm not sure I understood.
This is very simply and promising addon - looking for updates. I would love to see some more options!
Thank youuu. demo versions for new tools will be available in the next update, also working on making the current measurements system more automatic. If you have any suggestions, please do post them on the "report issues" website, I'd be happy to try and implement it
great add-on. !!! 1 question though. Is it possible to UNCadify? or revert.
Not yet, at least not automatically, you have to manually change the viewport display settings. But you do bring up a valid point, I'm almost finished with a massive update and will make sure to add a button for that.
I tried this addon, but I found that it cannot make corresponding changes with the unit scale. I suggest improving it so that it can change with the unit scale. Because the unit system for jewelry design must be metric and the unit scale must be set to 0.001. If you don't consider the actual size unit scale, this is a good addon.
