Extensions
  • Home
  • Add-ons
  • Themes
  • Approval Queue
  • About
  • Upload Extension
  • Sign in
  • BLENDER.ORG
    • Download
    • What's New
    LEARNING & RESOURCES
    DEVELOPMENT
    • Developers Blog
    • Benchmark
    • Blender Conference
    DONATE
    • Development Fund
    • One-time Donations
All Add-ons
Add-on MagicaVoxel VOX format
Importer addon for MagicaVoxel vox files.
Add-on by AstrorEnales
About What's New Permissions Reviews Version History
Import options for meshing, materials, and more Import MagicaVoxel hierarchy into blender Adjust the size of imported voxels Multiple meshing modes: cubes, quads, greedy
Extension to import MagicaVoxel (.vox) files. Supports multiple meshing, color, and material modes as well as joining all meshes and adjusting the voxel size.
Import Hierarchy
This options determines whether the hierarchy from MagicaVoxel is imported as empty axis objects in blender and all transformations (translation and rotation) are applied hierarchically. If not, all transformations are calculated and applied to each model and no hierarchy parent structure is created.
Join Models
This option allows all models in the MagicaVoxel file to be merged into one. Joining is done on a voxel basis and before meshing which is superior to just combining the blender meshes for generating the voxel hull and greedy meshing.
Voxel Size
The voxel size parameter can be used to define the unit voxel size. The example below shows a voxel model imported with voxel size 1.0, 1.5, and 2.0.
Material Modes
MagicaVoxel files contain a color palette and additional material properties per color in the palette. This addon supports different modes how this information is imported.
⚠️ Please note: Additional material props are still experimental and under development
Mode Description
Ignore Neither colors nor materials are imported.
Vertex Color Only the color palette will be imported and assigned to face vertex colors. A simple material is added using the vertex colors as 'Base Color'.
Material Per Color A material is added per color in the color palette and assigned to the faces material index.
Materials As Texture The color palette is created as a 256x1 texture. A simple material is added using this texture.
Textured Models (UV unwrap) Each model is assigned a material and texture with UV unwrap. (Only usable/sensible for Greedy meshing)
Import Material Properties
Depending on the material mode, additional material properties are either added as a separate vertex color layer, texture, or blender material nodes.
Mode Description
Vertex Color + Prop The color palette and certain material properties are assigned as vertex color layers. A simple material is added using the vertex color layers.
Material Per Color + Prop A material is added per color in the color palette and assigned to the faces material index. Additional material properties are stored for each material.
Materials As Texture + Prop The color palette and certain material properties are created as a 256x1 texture. A simple material is added using these textures.
Textured Models (UV unwrap) + Prop Each model is assigned a material and textures with UV unwrap. (Only usable/sensible for Greedy meshing)
To simplify the workflow from MagicaVoxel to "Game Ready" assets the "Textured Models (UV unwrap)" material model generates textures for base color, emission, roughness, and metallic in combination with UV unwrapping the model faces onto these textures.
As game assets are generally only sensible as optimized meshes, this material mode is only usable/sensible for the "Greedy" meshing mode.
Voxel Hull
This option is only available for certain meshing types and implicitly active for others. If checked, each model is analyzed to find the voxel hull and all other voxels inside the model are deleted/ignored.
Meshing Types
This addon supports different methods of representing the loaded voxel models.
Voxel as Models
Voxel as models meshing generates a six-sided cube for each voxel as separate models. Depending on the voxel hull option, cubes are only generated for the hull or all voxels defined in the model.
⚠️ Beware that this option may be slow as alot of cube models may be generated!
Simple Cubes
Simple cubes meshing generates a six-sided cube for each voxel combined in one mesh per model. Depending on the voxel hull option, cubes are only generated for the hull or all voxels defined in the model.
Simple Quads
Simple quads meshing generates the voxel hull of all models and creates only faces where voxel cube faces are visible from outside.
Greedy
Greedy meshing is equivalent to simple quads as it only creates faces of the voxel hull visible from outside, with the addition of greedily joining quads where possible.
What's New
1.5.6 March 14th, 2025
  • Fix textured models (UV unwrap) material texture creation
See all versions
Permissions
This extension requests the following permission:
  • Files
    Import VOX from disk
Developer
AstrorEnales
Rating
Leave a review
Version
1.5.6
Updated
3 mo
Published
June 28th, 2024
Downloads
9203
Size
23.6 KB
Blender 4.2  and newer
Website
github.com/AstrorEnales/blender_magicavoxel
Report Issues
github.com/AstrorEnales/blender_magicavoxel/issues
Licenses
GNU General Public License v3.0 or later
MIT License
Import-Export
...or download and Install from Disk
  • 23.6 KB
Reviews
See all
Be the first to review.
  • About
  • Terms of Service
Download
  • Latest Blender
  • Blender LTS
  • Blender Benchmark
  • Previous Versions
  • Experimental Builds
  • Source Code
  • Release Notes
  • Requirements
Organization
  • People
  • Jobs
About
  • Blender Foundation
  • Blender Institute
  • License
  • Logo & Trademark
  • Credits
Articles
  • News
  • Press Releases
  • User Stories
Get Involved
  • Dashboard
  • Development
  • Education
Support
  • Community
  • FAQ
Developers
  • Get Started
  • Docs
  • Forum
  • YouTube
  • Python API
Blender Conference
Follow Blender
Support Blender
  • Donate
  • One-time Donation
