A Blender add-on that adds additional batch rename operators
Features
The add-on allows you to easily batch rename:
- Modifiers/Constraints
- Vertex Groups
Functions
This add-on has 10 settings:
- Operator: Switch between different batch renaming operators
- Objects: Set renaming target to objects only.
- Bones: Set renaming target to bones only.
- Modifiers: Rename modifiers names.
- Constraints: Rename constraint names. When the target is set to bones, it will automatically switch to constraints, as armatures don't contain modifiers.
- Selected: Rename only the selected objects.
- All: Rename all objects in the scene. When the target is set to bones only, rename all bones on the active armature.
- Find & Replace: Find the target name and replace it.
- Prefix: Add the new name at the beginning of the old name.
- Suffix: Add the new name at the end of the old name.
How to Use
Right click on the viewport (in Object or Pose Mode) and you should find the Additional Batch Rename on the menu.
The vertex group renaming is MUCH welcomed.
