- Yukimi tuki changed review status to Awaiting Review
- 1 mo
Extension is ready for initial review
This is an add-on that creates a node that projects a camera map according to the appearance of the image set in the camera's "background".
The add-on panel appears in the node tab of the sidebar above the shader editor
Select the camera you want to use for projection from the camera pulldown and select the background you want to use. If no background image is set for the specified camera, items under "Background" will not be displayed. After specifying the camera with the sketch set, select the image you want to use from the sketch dropdown. When you press the Make CameraProjection Nodes button A node group will be created with a name such as [camera name]_[image name]_Projection.
If the material is displayed in the shader editor, add the created node group to the material If the material is not displayed or you want to use it with another material, Select from the group items in the Add menu.
By connecting the color output of the created node group to the color input of the shader The image will be projected from the camera as specified in the sketch.
If you use an image transparent with alpha for the sketch, The color specified in the color input or the color combined with the image will be output.
There is also a function that uses the color input value when the angle between the camera and the projected surface is larger than the limit angle specified. You can set the boundary between angle restrictions to be a gradation in the blur settings.
No changelog for this release.
Pretty neat add-on. Approving as it is.
Some suggestions for future versions:
Blender's UI in English always capitalize the initial letter of the strings. So to make the add-on feel more integrated with Blender you could:
In a similar way the panel name:
We've added new mandatory fields: Featured Image and Icon. Featured Image is shown at the home page instead of the first preview image, and icon is shown in the extension's title (and later will be shown in Blender as well).
Could you please update your extension with an icon and a featured image?
Apologies for the late heads up.
Sign in to comment.
