- hisanimations changed review status to Awaiting Review
- 1 mo
Extension is ready for initial review
A simple addon to manage and keyframe the visibility of objects by batch. This affects both rendered and viewport visibility.
Object -> Show/Hide
This addon has two modes: "Show now, hide next" and "Hide before, show now". It will insert a keyframe on the current frame to enable visibility, then depending on which mode you choose, the addon will insert a keyframe before or after the current frame to hide the object.
No code change - adjust .toml manifest to match bl_info in init.py
Extension works and the information within the .toml
files is correct.
Small thing not very important:
Version numbers in the bl_info
inside the __init__.py
file do not match those in the .toml
file.
Thanks for your contribution. I will approve the extension, but there are a few adjustments needed for the description.
Could you please replace the image to use a JPG instead? This image would go from 800kb to 180kb. It can probably be even less given the size you actually need it.
And small typo: The correct is "add-ons", not "addons".
Sure thing, I will update the extension with the suggested details. Thank you for the approval!
We've added new mandatory fields: Featured Image and Icon. Featured Image is shown at the home page instead of the first preview image, and icon is shown in the extension's title (and later will be shown in Blender as well).
Could you please update your extension with an icon and a featured image?
Apologies for the late heads up.
uploaded new version: 1.0.2
fixed .toml manifest, added icon and feature image!
Sign in to comment.
