- Vasyl Pauk changed review status to Awaiting Review
- 2 w
Extension is ready for initial review
Dark deep blues and purples speckled with pink and green accents! A fun yet functional theme, perfect to spice up your work window đ˝đ¸
I've put a lot of thought and experimentation into balancing out the colors and values for this theme. It should be easy on the eye but never at the cost of affecting your relative color perception of whatever you're working on!
Every workspace and window in this theme is accordingly changed but of course there are some workspaces i don't use as much so if you find some discrepancies with the theme, reach out and i'll try to fix it asap!
Not a big deal but the whole permissions section can be removed from the manifest since it only applies to add-ons:
# Optional: add-ons can list which resources they will require:
# * "files" (for access of any filesystem operations)
# * "network" (for internet access)
# * "camera" (to capture photos and videos)
# * "microphone" (to capture audio)
# permissions = ["files", "network"]
Should be fixed! (just wasn't sure if it was ok to remove lines from the manifest file :p)
Thanks!
And yes, pretty much everything that's commented out (starts with #
) can be removed :)
đ
uploaded new version: 5.3.3
Sign in to comment.
